Checkbox List
    Alias: Umbraco.CheckBoxList
    Returns: IEnumerable<string>
    Displays a list of preset values as a list of checkbox controls. The text saved is a IEnumerable collection of the text values.
    Unlike other property editors, the Prevalue IDs are not directly accessible in Razor.
    Data Type Definition Example
    True/Checkbox List Definition
    Content Example
    Checkbox List Example
    MVC View Example
    Without Modelsbuilder
        if (Model.HasValue("superHeros"))
            <ul>
                @foreach (var item in Model.Value<IEnumerable<string>>("superHeros"))
                    <li>@item</li>
            </ul>
    With Modelsbuilder
        if (Model.SuperHeros.Any())
            <ul>
                @foreach (var item in Model.SuperHeros)
                    <li>@item</li>
            </ul>
    Add values programmatically
    @using Newtonsoft.Json
        // Set the value of the property with alias 'superHeros'.
        content.SetValue("superHeros", JsonConvert.SerializeObject(new[] { "Umbraco", "CodeGarden"}));
        // Save the change
        contentService.Save(content);
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.SuperHeros).Alias, JsonConvert.SerializeObject(new[] { "Umbraco", "CodeGarden"}));
