Color Picker
    Alias: Umbraco.ColorPicker
    Returns: String (Hexadecimal)
    Returns: Umbraco.Core.PropertyEditors.ValueConverters.ColorPickerValueConverter.PickedColor (When using labels)
    The Color picker allows you to set some predetermined colors that the editor can choose between.
    It's possible to add a label to use with the color.
    Data Type Definition Example
    Color Picker Data Type Definition
    Content Example
    Color Picker Content
    Example with Modelsbuilder
        var hexColor = Model.Color;
        // Define the label if you've included it
        String colorLabel = Model.Color.Label;
        if (hexColor != null)
            <div style="background-color: #@hexColor">@colorLabel</div>
    Example without Modelsbuilder
    @using Umbraco.Core.PropertyEditors.ValueConverters
        var hexColor = Model.Value("Color");
        var colorLabel = Model.Value<ColorPickerValueConverter.PickedColor>("Color").Label;
    Add values programmatically
        // Set the value of the property with alias 'color'.
        // The value set here, needs to be one of the prevalues on the Color Picker
        content.SetValue("color", "38761d");
        // Save the change
        contentService.Save(content);
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.Color).Alias, "38761d");
