Eye Dropper Color Picker
    Alias: Umbraco.ColorPicker.EyeDropper
    Returns: object
    The Eye Dropper Color picker allows you to choose a color from the full color spectrum using HEX and RGBA.
    Data Type Definition Example
    Eye Dropper Color Picker Data Type Definition
    Content Example
    Eye Dropper Color Picker Content
    Example with Modelsbuilder
        var color = Model.Color?.ToString();
        if (!string.isNullOrEmpty(color))
            <div style="background-color: @color"></div>
    Example without Modelsbuilder
        var color = Model.Value<string>("Color");
    Add values programmatically
        // Set the value of the property with alias 'color'.
        content.SetValue("color", "#6fa8dc");
        // Save the change
        contentService.Save(content);
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.Color).Alias, "#6fa8dc");
        // Set the value of the property with alias 'theme'
        content.SetValue(Home.GetModelPropertyType(x => x.Theme).Alias, "rgba(111, 168, 220, 0.7)");
