File upload
    Alias: Umbraco.UploadField
    Returns: string
    Adds an upload field, which allows documents or images to be uploaded to Umbraco.
    Data Type Definition Example
    Content Example
    Content Example Empty Content Example
    In code, the property is a string, which references the location of the file.
    Example: "/media/o01axaqu/guidelines-on-remote-working.pdf"
    MVC View Example
    Without Modelsbuilder
        if (Model.HasValue("myFile"))
            var myFile = Model.Value<string>("myFile");
            <a href="@myFile">@Path.GetFileName(myFile)</a>
    With Modelsbuilder
    @using ContentModels = Umbraco.Web.PublishedModels;
    @if (!Model.HasValue(Model.MyFile))
       <a href="@Model.MyFile">@Path.GetFileName(Model.MyFile)</a>
    Add values programmatically
    See the example below to see how a value can be added or changed programmatically. To update a value of this property editor you need the Content Service and the Media Service.
        // Get access to MediaService
        var mediaService = Services.MediaService;
        // Create a variable for the GUID of the parent where you want to add a child item
        // Create a variable for the file you want to upload, in this case the Our Umbraco logo
        var imageUrl = "https://our.umbraco.com/assets/images/logo.svg";
        // Create a request to get the file
        var request = WebRequest.Create(imageUrl);
        var webResponse = request.GetResponse();
        var responseStream = webResponse.GetResponseStream();
        // Get the file name
        var lastIndex = imageUrl.LastIndexOf("/", StringComparison.Ordinal) + 1;
        var filename = imageUrl.Substring(lastIndex, imageUrl.Length - lastIndex);
        // Create a media file
        var media = mediaService.CreateMediaWithIdentity("myImage", -1, "File");
        media.SetValue(Services.ContentTypeBaseServices, "umbracoFile", filename, responseStream);
        // Save the created media
        mediaService.Save(media);
        // Get the published version of the media (IPublishedContent)
        var publishedMedia = Umbraco.Media(media.Id);
        // Set the value of the property with alias 'myFile'
        content.SetValue("myFile", publishedMedia.Url());
        // Save the child item
        contentService.Save(content);
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.MyFile).Alias, publishedMedia.Url();
