Markdown editor
    Alias: Umbraco.MarkdownEditor
    Returns: System.Web.HtmlString
    This built-in editor allow the user to use the markdown formatting options, from within a tinyMCE-like interface.
    Data Type Definition Example
    Definition Example
    There are two settings available for manipulating the Markdown editor property.
    • Preview toggles if a preview of the markdown should be displayed beneath the editor in the content view.
    • Default value is inserted if no content has been saved to the document type using this property editor.
    Content Example
    Content Example
    Explanation of buttons from left to right
    Function Shortcut Further explanation
    toggle bold text Ctrl + B
    toggle italic text Ctrl + I
    insert link Ctrl + L This opens the Select Link interface.
    toggle quote Ctrl + Q
    toggle code block Ctrl + K
    insert image Ctrl + G This opens the Select Media interface.
    toggle ordered list Ctrl + O
    toggle unordered list Ctrl + U
    toggle heading Ctrl + H This toggles between h1, h2 and off.
    toggle a hr
    undo Ctrl + Z
    redo Ctrl + Y
    Other functionality
    Function Shortcut
    select all Ctrl + A
    copy Ctrl + C
    paste Ctrl + V
    MVC View Example
    With Modelsbuilder
    @Model.MyMarkdownEditor
    Without Modelsbuilder
    @Model.Value("MyMarkdownEditor")
    Add values programmatically
        // Create markdown value
        var markdownValue = new HtmlString("#heading  \n**strong text**");
        // Set the value of the property with alias 'myMarkdownEditor'.
        content.SetValue("myMarkdownEditor", markdownValue);
        // Save the change
        contentService.Save(content);
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.MyMarkdownEditor).Alias, markdownValue);
