Member Group Picker
    Alias: Umbraco.MemberGroupPicker
    Returns: string
    The Member Group Picker opens a panel to pick one or more member groups from the Member section. The value saved is of type string (comma separated IDs).
    Data Type Definition Example
    Member Group Picker Type Definition
    Content Example
    Member Grouep Picker Content
    MVC View Example
    Without Modelsbuilder
    @if (Model.HasValue("memberGroup"))
        var memberGroup = Model.Value<string>("memberGroup");
        <p>@memberGroup</p>
    With Modelsbuilder
    @if (!string.IsNullOrEmpty(Model.MemberGroup))
        <p>@Model.MemberGroup</p>
    Add values programmatically
        var guid = new Guid("796a8d5c-b7bb-46d9-bc57-ab834d0d1248");
        // Set the value of the property with alias 'memberGroup'. The value is the specific ID of the member group
        content.SetValue("memberGroup", 1067);
        // Save the change
        contentService.Save(content);
    You can also add multiple groups by creating a comma separated string with the desired member group IDs.
        content.SetValue("memberGroup", "1067","1068");
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.MemberGroup).Alias, 1067);
