Member Picker
    Alias: Umbraco.MemberPicker
    Returns: IPublishedContent
    The member picker opens a panel to pick a specific member from the member section. The value saved is of type IPublishedContent.
    Data Type Definition Example
    Media Picker Data Type Definition
    Content Example
    Member Picker Content
    MVC View Example
    Without Modelsbuilder
        if (Model.HasValue("author"))
            var member = Model.Value<IPublishedContent>("author");
            @member.Name
    With Modelsbuilder
        if (Model.Author != null)
            var member = Model.Author;
            @member.Name
    Add values programmatically
        // Create a variable for the GUID of the member ID
        var authorId = Guid.Parse("ed944097281e4492bcdf783355219450");
        // Create a variable for the UDI of the member
        var authorUdi = Udi.Create(Umbraco.Core.Constants.UdiEntityType.Member, authorId);
        // Set the value of the property with alias 'author' to the memberUdi.
        content.SetValue("author", authorUdi);
        // Save the change
        contentService.Save(content);
        // Get the page using it's id
        var udi = Udi.Create(Umbraco.Core.Constants.UdiEntityType.Member, authorId);
        content.SetValue(Home.GetModelPropertyType(x => x.Author).Alias, udi);
