Multinode Treepicker
    Alias: Umbraco.MultiNodeTreePicker
    Returns: IEnumerable<IPublishedContent>
    Settings
    The Multinode Treepicker allows you to configure the type of tree to render and what part of the tree that should be rendered. For content it allows you to select a dynamic root node based on the current document using the multinode tree picker.
    Node type: set the type of node, the root node of the tree, or query for the root node
    For querying for a root node, you can use dynamic placeholders in the XPath query, following the below sample queries
    // get the first textpage below the current document
    $current/textpage: current page or closest found ancestor
    // get a descendant of type news article somewhere below the parent
    $parent//newsArticle: parent page or closest found ancestor
    // go to the root of the content tree
    $root
    // go the ancestor at @level=1 where your website root usually is.
    $site: Ancestor node at level 1
    It is important to notice that all placeholders above act against published content only. So if you, therefore, try to fetch $parent of the current document, then Umbraco will return that or its closest published ancestor. So in case, the parent is not published, it will try the parent of that parent, and so on.
    Filter out items with type: allow or disallow tree nodes with a certain content type alias.
    Enter typeAlias,altTypeAlias to only allow selecting nodes with those alias'. Enter !typeAlias,altTypeAlias to only allow selecting nodes not with those alias'.
    Minimum/maximum number of items: set a limit on the number of items allowed to be selected.
    Data Type Definition Example
    Multinode Treepicker Data Type Definition
    Content Example
    MVC View Example
    Without Modelsbuilder
        var typedMultiNodeTreePicker = Model.Value<IEnumerable<IPublishedContent>>("featuredArticles");
        foreach (var item in typedMultiNodeTreePicker)
            <p>@item.Name</p>
    Without Modelsbuilder (Maximum number of items set to 1)
        var typedMultiNodeTreePicker = Model.Value<IPublishedContent>("featuredArticle");
        if (typedMultiNodeTreePicker != null)
            <p>@typedMultiNodeTreePicker.Name</p>
    With Modelsbuilder
        var typedMultiNodeTreePicker = Model.FeaturedArticles;
            <p>@item.Name</p>
    Add values programmatically
        // Get the pages you want to assign to the Multinode Treepicker
        var page = Umbraco.Content("665d7368-e43e-4a83-b1d4-43853860dc45");
        var anotherPage = Umbraco.Content("1f8cabd5-2b06-4ca1-9ed5-fbf14d300d59");
        // Create Udi's of the pages
        var pageUdi = Udi.Create(Constants.UdiEntityType.Document, page.Key);
        var anotherPageUdi = Udi.Create(Constants.UdiEntityType.Document, anotherPage.Key);
        // Create a list of the page udi's
        var udis = new List<string>{pageUdi.ToString(), anotherPageUdi.ToString()};
        // Set the value of the property with alias 'featuredArticles'.
        content.SetValue("featuredArticles", string.Join(",", udis));
        // Save the change
        contentService.Save(content);
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.FeaturedArticles).Alias, string.Join(",", udis));
