Rich Text Editor
    Alias: Umbraco.TinyMCE
    Returns: HTML
    The Rich Text Editor (RTE) is based on tinymce and is highly configurable. Depdending on the configuration, it will give your content editors more flexibility when working with content that should be more than only plain text.
    Configuration options
    Customize everything from toolbar options to editor size to where pasted images are saved.
    RTE Styles
    Use CSS to define specific editor styles and add them to the RTE.
    Data Type Definition Example
    Rich Text Editor - Data Type
    Content Example
    Rich Text Editor - Content
    MVC View Example
    Without Modelsbuilder
        if (Model.HasValue("richText")){
            <p>@(Model.Value("richText"))</p>
    With Modelsbuilder
        if (!string.IsNullOrEmpty(Model.RichText.ToString()))
            <p>@Model.RichText</p>
    Add values programmatically
        // Create a variable for the desired value
        var htmlValue = new HtmlString("Add some text <strong>here</strong>");
        // Set the value of the property with alias 'richText'.
        content.SetValue("richText", htmlValue);
        // Save the change
        contentService.Save(content);
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.RichText).Alias, "Add some text <strong>here</strong>");
