True/False
    Returns: Boolean
    True/False is a checkbox which saves either 0 or 1, depending on the checkbox being checked or not.
    Data Type Definition Example
    True/False Data Type Definition
    The True/False property has a setting which allows you to set the default value of the checkbox, either checked (true) or unchecked (false). This property was added in Umbraco 7.4.2.
    Content Example
    No Edit Content Example
    Typed
        foreach (IPublishedContent page in Model.Content.Children){
            if (!page.GetPropertyValue<bool>("umbracoNaviHide"))
                <p>@page.Name</p>
    Dynamic (Obsolete)
    See Common pitfalls for more information about why the dynamic approach is obsolete.
        foreach (var page in CurrentPage.Children){
            if (!page.umbracoNaviHide){
                <p>@page.Name</p>
