Toggle
    Returns: Boolean
    Toggle is a standard checkbox which saves either 0 or 1, depending on the checkbox being checked or not.
    Data Type Definition Example
    True/False Data Type Definition
    The Toggle property has a setting which allows you to set the default value of the checkbox, either checked (true) or unchecked (false).
    It is also possible to define a label, that will be displayed next to the checkbox on the content.
    Content Example
    No Edit Content Example
    MVC View Example
    Without Modelsbuilder
        if (!Model.Value<bool>("myCheckBox"))
            <p>The Checkbox is not checked!</p>
    With Modelsbuilder
        if (!Model.MyCheckbox)
    Add values programmatically
        var guid = new Guid("796a8d5c-b7bb-46d9-bc57-ab834d0d1248");
        // Set the value of the property with alias 'myCheckBox'
        content.SetValue("myCheckBox", true);
        // Save the change
        contentService.Save(content);
        // Get the page using it's id
        content.SetValue(Home.GetModelPropertyType(x => x.MyCheckBox).Alias, true);
