Creating More Pages
    Using a Maintainable Template Structure
    We've seen how to create a Document Type. If we wanted to create a three-page site containing; Home, News and Contact Us pages. We could create a Document Type with a corresponding template for each and copy the same HTML code into each template. Afterwards we could make the custom changes to each separate template for these pages.
    Though this would work, but once a site starts to grow this would lead to problems. For instance changing anything in the header or footer would need to be done on each template. It also means we'd need the user to enter the same content for the footer on each page.
    Umbraco provides us with an elegant solution for a consistent base template - those familiar with MVC will recognise it.
    To start we're going to unpick a little bit of what we did in creating the homepage to sit the homepage template under a master.
    Create a Master Template
    Go to the Settings > Templates and open up the tree. At the moment we only have our Homepage template. Hover over the Templates menu and click the menu ... button. Create a new template called Master, click + Create and then give it the name "Master" . Remember to click Save.
    Master Template
    Figure 22 - Master Template
    Now we're going to move the Homepage template under the Master template. To do this select the Settings > Homepage node and from the Properties tab > Master template dropdown, select "Master" and then click Save. This will update the Razor code section to change Layout = null; to Layout = "Master.cshtml";
    Due to a bug in older versions of Umbraco you may need to click off the Homepage node and back on to see this update.
    Homepage Template now sits under the Master
    Figure 23 - Homepage Template now sits under the Master
    Now we need to move the parts of our HTML template that are common across all pages into the Master. Now we need to move the parts of our HTML template that are common across all pages into the Master. It might be slightly different for different websites and you'll need to consider if all pages contain a <div id="main"> section so can you put this in the master or of it belong to only certain pages?
    For this site, we'll assume this is part of the child page. In the template edit screen cut everything from the closing curly brace to line 37 <div id="main-container"> - we're going to move the header and nav of the site to the master template. Cut this and click Save.
    Homepage Template After Cutting the Header
    Figure 24 - Homepage Template After Cutting the Header
    Now click on your Master template and paste this HTML markup after the closing curly brace and remember to click Save.
    Master Template after Pasting the Header
    Figure 25 - Master Template after Pasting the Header
    At the end of this markup we need to tell Umbraco to insert the child template's content - this is done by adding the code @RenderBody() at the end (around line 37). Click Save.
    Adding RenderBody() to the Master Template
    Figure 26 - Adding RenderBody() to the Master Template
    Now we'll do the same with the footer content. Cut everything from the opening of the _footer-container _ div (approximately line 35) from the Settings > Templates > Homepage > template tab, click Save and then paste this into the Master template under the @RenderBody field we've added. Remember to click Save.
    Completed Master Template
    Figure 27 - Completed Master Template
    Now we've done a lot of work - and what we should see if we refresh our localhost page is nothing has changed! If you have a compilation error you've perhaps mistyped @RenderBody(). If you're missing any content (header or footer) check that what you have in the templates matches the following:
        Layout = null;
    }<!doctype html>
    <!--[if lt IE 7]> <html class="no-js ie6 oldie" lang="en"> <![endif]-->
    <!--[if IE 7]>    <html class="no-js ie7 oldie" lang="en"> <![endif]-->
    <!--[if IE 8]>    <html class="no-js ie8 oldie" lang="en"> <![endif]-->
    <!--[if gt IE 8]><!--> <html class="no-js" lang="en"> <!--<![endif]-->
    <head>
        <meta charset="utf-8">
        <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
        <title></title>
        <meta name="description" content="">
        <meta name="author" content="">
        <meta name="viewport" content="width=device-width,initial-scale=1">
        <link rel="stylesheet" href="css/style.css">
        <script src="js/libs/modernizr-2.0.6.min.js"></script>
    </head>
    <body>
        <div id="header-container">
            <header class="wrapper clearfix">
                <h1 id="title">@Umbraco.Field("pageTitle")</h1>
                <nav>
                    <ul>
                        <li><a href="#">nav ul li a</a></li>
                    </ul>
                </nav>
            </header>
        @RenderBody()
        <div id="footer-container">
            <footer class="wrapper">
                <h3>@Umbraco.Field("footerText")</h3>
            </footer>
    </body>
    </html>
    Figure 28 - Complete Master Template
        <div id="main" class="wrapper clearfix">
            <article>
                <header>
                    @Umbraco.Field("bodyText")
                </header>
                <section>
                    <h2>article section h2</h2>
                    <p>Lorem ipsum dolor sit amet, consectetur adipiscing elit. Aliquam sodales urna non odio egestas tempor. Nunc vel vehicula ante. Etiam bibendum iaculis libero, eget molestie nisl pharetra in. In semper consequat est, eu porta velit mollis nec. Curabitur posuere enim eget turpis feugiat tempor. Etiam ullamcorper lorem dapibus velit suscipit ultrices. Proin in est sed erat facilisis pharetra.</p>
                </section>
                <section>
                </section>
                <footer>
                    <h3>article footer h3</h3>
                    <p>Lorem ipsum dolor sit amet, consectetur adipiscing elit. Aliquam sodales urna non odio egestas tempor. Nunc vel vehicula ante. Etiam bibendum iaculis libero, eget molestie nisl pharetra in. In semper consequat est, eu porta velit mollis nec. Curabitur posuere enim eget turpis feugiat tempor.</p>
                </footer>
            </article>
            <aside>
                <h3>aside</h3>
                <p>Lorem ipsum dolor sit amet, consectetur adipiscing elit. Aliquam sodales urna non odio egestas tempor. Nunc vel vehicula ante. Etiam bibendum iaculis libero, eget molestie nisl pharetra in. In semper consequat est, eu porta velit mollis nec. Curabitur posuere enim eget turpis feugiat tempor. Etiam ullamcorper lorem dapibus velit suscipit ultrices.</p>
            </aside>
        </div> <!-- #main -->
    </div> <!-- #main-container -->
    Figure 29 - Complete Homepage Template
    If you're new to these concepts then I don't think what we've done is going to make much sense until we make our next page.
    Next - Creating Master Template Part 2
    Part 2 - using the Master template to create new page types.
