Go to docs.umbraco.com for documentation for Umbraco 9 and newer versions.
    Introduction
    The following sections of the "Creating a Basic Site" tutorial provide step by step instructions through an Umbraco website build starting from a set of flat HTML, CSS and JavaScript files. It will allow you to take any website "template" and install it into a fresh Umbraco and wire up the sections that need content managing in Umbraco.
    What You’ll Need
    To take you through a demo of installing a basic site in Umbraco you need the following:
    Getting Started
    Installing an Empty Umbraco
    This guide doesn’t cover the installation of Umbraco – follow the instructions in https://our.umbraco.com/documentation/Installation.
    When you see the first screen click customize. Either fill in your MS SQL blank DB credentials or use the CE option. On the final screen use the “No thanks I do not want to use a starter website”.
    Umbraco Installation Splash Screen
    Figure 1 - Installation Splash Screen - note the Customize link
    Install a starter website
    Figure 2 - Install a starter website - No Thanks!
    Checking you have an Empty Umbraco Install
    When you hit your local host address (http://localhost or whatever you’ve set up) you should see the Umbraco empty page screen.
    This is correct – we have a blank, empty Umbraco website
    Figure 3 - This is correct – we have a blank, empty Umbraco website!
    If you can see the Umbraco Starter kit site you’ve missed the option to install Umbraco with no starter site.
    You should NOT see this!
    Figure 4- You should NOT see this!
    You need to reinstall Umbraco if you can see the starter kit. If you did a manual install you can delete all files in the directory where your local host is being served from. Then, copy the Umbraco zip contents back in and then hit localhost in your browser.
    Preparing the Initializr Template Site
    Now unzip the Initializr contents to a folder onto your desktop (or a place of your choosing). Now open the index.html from this directory in your preferred browser to see the template – you can see it’s full of lovely filler text with dummy links. We’re going to turn this into a fully fledged, Umbraco-powered site!
    The Initializr Template
    Figure 5 - The Initializr Template
    Log into your Umbraco installation (e.g. go to http://localhost/umbraco in your browser). You should be faced with an empty Umbraco installation – but where to start!?
    A barren, empty Umbraco installation
    Figure 6 - A barren, empty Umbraco installation
    Next - Creating Your First Document Type
    How to create Document Types and what they do.
