Cache static assets
    Example to cache static assets by file extension, but excluding Umbraco BackOffice assets.
    using Microsoft.AspNetCore.Builder;
    using Microsoft.AspNetCore.Http;
    using Microsoft.AspNetCore.Http.Headers;
    using Microsoft.Extensions.DependencyInjection;
    using Microsoft.Extensions.Options;
    using Microsoft.Net.Http.Headers;
    using System;
    using System.IO;
    using Umbraco.Cms.Core.Composing;
    using Umbraco.Cms.Core.Configuration.Models;
    using Umbraco.Cms.Core.DependencyInjection;
    using Umbraco.Extensions;
    using IHostingEnvironment = Umbraco.Cms.Core.Hosting.IHostingEnvironment;
    namespace My.Site.Composers;
    public class StaticFilesComposer : IComposer
        public void Compose(IUmbracoBuilder builder)
            => builder.Services.AddTransient<IConfigureOptions<StaticFileOptions>, ConfigureStaticFileOptions>();
        private class ConfigureStaticFileOptions : IConfigureOptions<StaticFileOptions>
            // These are the extensions of the file types we want to cache (add and remove as you see fit)
            private static readonly HashSet<string> _cachedFileExtensions = new(StringComparer.OrdinalIgnoreCase)
                ".ico",
                ".css",
                ".js",
                ".svg",
                ".woff2"
            private readonly string _backOfficePath;
            public ConfigureStaticFileOptions(IOptions<GlobalSettings> globalSettings, IHostingEnvironment hostingEnvironment)
                => _backOfficePath = globalSettings.Value.GetBackOfficePath(hostingEnvironment);
            public void Configure(StaticFileOptions options)
                => options.OnPrepareResponse = ctx =>
                    // Exclude Umbraco backoffice assets
                    if (ctx.Context.Request.Path.StartsWithSegments(_backOfficePath))
                        return;
                    // Set headers for specific file extensions
                    var fileExtension = Path.GetExtension(ctx.File.Name);
                    if (_cachedFileExtensions.Contains(fileExtension))
                        ResponseHeaders headers = ctx.Context.Response.GetTypedHeaders();
                        // Update or set Cache-Control header
                        CacheControlHeaderValue cacheControl = headers.CacheControl ?? new CacheControlHeaderValue();
                        cacheControl.Public = true;
                        cacheControl.MaxAge = TimeSpan.FromDays(365);
                        headers.CacheControl = cacheControl;
    Cache images in ImageSharp
    For setting Cache-Control max-age header for images processed by the ImageSharp middleware, you can set the Umbraco:CMS:Imaging:Cache:BrowserMaxAge setting.
    See the Images Settings article for more information.
