I have a problem in searching and sorting with examine search as I need sorting according to the sort order of the parent nodes and then their child nodes as set in umbraco backend.
I have "Football Shirts" as parent node whose sub-nodes and their descendants need to be sorted according to sort order in backend.
Sorting should be in ascending order. "Cut and Sew" has sort order 0 and "Sublimated" has sort order 1. So, It should list all the items in "Cut and Sew" first according to their own sort order and then the items in "Sublimated" respectively.
Currently, it is getting all items in "Football Shirts" whether they are in "Cut and Sew" or in "Sublimated" and sort them according to their sort order. Both "Cut and Sew" and "Sublimated" have items with same sort order and it is showing items in sequence by neglecting their parent's sort order.
Sort order of products on product page needs to reflect Umbraco sort order
I have "Football Shirts" as parent node whose sub-nodes and their descendants need to be sorted according to sort order in backend. Sorting should be in ascending order. "Cut and Sew" has sort order 0 and "Sublimated" has sort order 1. So, It should list all the items in "Cut and Sew" first according to their own sort order and then the items in "Sublimated" respectively.
