  • gilad 185 posts 425 karma points
    Dec 11, 2011 @ 15:18
    gilad
    Tags datatype issue
    hii everyone
    is it possible to extend the tags data type for showing a check box list with all added tags from same document type?
    i mean : let say i create a new node(NODE1) and set two tags : tag1 , tag2
    now.. if i create another same documentTYPE new node(NODE2) the tags will be empty..
    i want the tag will be with this (tag1,tag2) checkbox list.. ( not checked ).
    if i add a new tag to NODE2 ( tag3 ).
    the tag checkbox list in NODE1 should be now :
    tag1(checked)
    tag2(checked)
    tag3(not checked)
    is there some pacakge for this?
    thanks in advance.
  • Rodion Novoselov 694 posts 859 karma points
    Dec 11, 2011 @ 15:30
    Rodion Novoselov
    Hi. Probably it's achievable by handling the Document.New event, so that to set the tag property to the required state on document creation.
    Dec 12, 2011 @ 14:37
    gilad
    hii rodion...
    thanks for replay but this event let me set a value for some property when create the node.
    i need the property to be empty.
    but a checkbox list( no checked ) with the rest of tags from the same document type..
    anyway... i creating a new dataType-usercontrol to handle with this issue...
