  • kullboys 1 post 71 karma points
    Nov 22, 2018 @ 07:07
    kullboys
    How to check for deleted images ?
    If you, in a Media Picker, pick an image and then deletes the image in the media section, the image id is still stored in the picker.
    How do I check for this scenario in Razor ?
    If I don't do anything the code will fail. Thanks.
  • Alex Skrypnyk 4888 posts 17641 karma points MVP 2x admin c-trib
    Nov 22, 2018 @ 10:23
    Alex Skrypnyk
    Hello
    Just check for null when rendering an image.
    Alex
  • Søren Kottal 352 posts 2004 karma points c-trib
    Nov 22, 2018 @ 10:43
    Søren Kottal
    You can check if the value of your media picker is null, like if (Model.MyMediaPicker == null) or if (Model.GetPropertyValue<IPublishedContent>("myMediaPicker") == null)
    For rendering the image ie.
    @if (Model.MyMediaPicker != null)
      <img src="@Model.MyMediaPicker.Url"/>
