  • Carlos Gómez 25 posts 55 karma points
    Dec 05, 2017 @ 16:58
    Carlos Gómez
    With Forms 6.0.5 TypeError: workflowResource.getAllWorkflowTypesWithSettings is not a function
    Hello
    Using Umbraco version 7.6.5 assembly: 1.0.6428.37121 and Forms 6.0.5 it is showing this error enter image description here
    It is when trying to open Workflow's window:
    Any clue?
    Thanks.
  • Julien Kulker 75 posts 427 karma points c-trib
    Apr 06, 2018 @ 09:43
    Julien Kulker
    got the same problem what goes wrong here?
    Apr 06, 2018 @ 12:13
    Julien Kulker
    So i didn't find a solution for it. But i know what the problem is at my end.
    I am using a 3rd Party plugin: Plumber that extends the workflow functionality. this 3rd Party plugin breaks Umbraco Forms.
    Uninstalling that plugin was the fix for me.
    So my guess for you is that the problem is in other plugin that is doing something with the workflow aswell
