  • Huw Reddick 543 posts 1744 karma points
    20 days ago
    Huw Reddick
    Problem syncing DocTypes
    Hi Stuart,
    I am trying to use the latest converge 8.0.12 on Umbraco version 8.17.1 but am unable to sync document type changes.
    Get the following error. Any ideas? it works fine in Umbraco 8.10.1
    Converge error when merging content type
    System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
       at System.ThrowHelper.ThrowKeyNotFoundException()
       at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
       at System.Collections.ObjectModel.KeyedCollection`2.get_Item(TKey key)
       at Com.StuartMullinger.Converge.Comparers.ContentTypeComparer.MergeContentType(ContentTypeModel remoteContentType, String key, ServiceContext Services, Int32 currentUserId)
       at Com.StuartMullinger.Converge.Controllers.ConvergeProcessor.MergeContentTypes(MergeParameters keys)
  • Stuart Mullinger 65 posts 311 karma points
    18 days ago
    Stuart Mullinger
    Hi Huw,
    I've found the problem: Umbraco has stopped access to the tabs as a dictionary in later versions. I have a fix, but need to run through some testing. New version likely next week sometime.
    Stuart.
    18 days ago
    Huw Reddick
    Excellent, thanks once again for your great support
    16 days ago
    Stuart Mullinger
    Hi again Huw,
    You should see the new version available now. Let me know if you still have problems.
    Stuart.
    1 week ago
    Huw Reddick
    Works a treat, thanks Stuart
