  • Bambu 4 posts 24 karma points
    Jul 28, 2011 @ 11:02
    Bambu
    how get a Media with Umbraco 4.7
    hi,
    i'm working with umbraco 4.7 and i'm trying to show a image. I use the next code but don't show the image. Anybody knows why?
    My xslt:
    <!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
    <xsl:variable name="mediaPropName" select="/macro/imagen" />
    <xsl:template match="/">
    <xsl:variable name="media" select="umbraco.library:GetMedia($currentPage/@alias=$mediaPropName, 0) " />
    <img src="{$media/umbracoFile}" alt="{$media/altText}" />
    </xsl:template>
    </xsl:stylesheet>
    Jul 28, 2011 @ 11:06
    Jeroen Breuer
    Are you using the Digibiz Advanced Media Picker to select your media? If you do you can use this sample.
    Jeroen
