  • Jesper Ordrup 1019 posts 1528 karma points MVP
    Aug 09, 2011 @ 18:44
    Jesper Ordrup
    Macro parameters
    Hi sir,
    Fantastic project. Thanks for sharing it.
    I'm using the damp multi with "Full media xml". This is brilliant as I then have the xml directy. And it all works when selecting the property directly in xslt.
    But if I choose to use specify which field to use in a macro paramenter then the value is always empty?
    Best
    Jesper
    Aug 09, 2011 @ 21:48
    Jesper Ordrup
    To clarify:
    If I do like this:
     <umbraco:Macro Alias="Stan_topimage" imgFile="[$topImage]" runat="server"></umbraco:Macro>
    .. and add imgFile as parameter to the macro ... then
    <xsl:value-of select="/macro/imgFile"/> returns nothing
    but
    <xsl:value-of select="$currentPage/topImage"/> works.
    Best
    Jesper
    Aug 09, 2011 @ 21:57
    Tom Fulton
    Hi Jesper,
    If I recall, you can't pass in XML data through macro parameter syntax, so the same thing happens for datatypes like Related Links.
    To work around this in the past I've instead passed in the alias of the property and retrieved the data from XSLT.
     <umbraco:Macro Alias="Stan_topimage" imgFileField="topImageField" runat="server"></umbraco:Macro>
    And in xslt:
    <xsl:param name="imgFileField" select="/macro/imgFileField" />
    <xsl:value-of select="$currentPage/* [not(@isDoc)][local-name() = $imgFileField]/DAMP/mediaItem/Image/umbracoFile"/>
    You could check recursively in the XSLT also.
    -Tom
    Aug 09, 2011 @ 22:24
    Jeroen Breuer
    Tom is right. You can't pass xml as a macro parameter. I think nowadays that's the only thing xml properties don´t support. You can get it with an XPath, the node factory or LinqToUmbraco. It´s your choice :).
    Jeroen
    Aug 10, 2011 @ 16:45
    Jesper Ordrup
    Thanks Tom and jeroen,
    I'll fetch it in xslt then.
    Best
    Jesper
