  • Madde 6 posts 26 karma points
    Mar 14, 2012 @ 13:58
    Madde
    Display images in specific folder
    Hello
    I have muliple places (divs. lists , etc) on my webiste i want to place images uploaded from Digibiz Advanced Media Picker 2.0.
    They are uploaded in separate folders så images placed in a "DIV A" is uploaded in one folder and images uploaded in another folder belongs to "DIV B".
    Now it's like this and it's posting images from all folders:
    <xsl:for-each select="$currentPage//mediaItem/Image">
        <li>
         <img src="{umbracoFile}" alt="bild"/>
        </li>
      </xsl:for-each>
    How do i post from only one of the folders?
    Is there an easy way to do this? anyone width examples?
    Thank you.
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Mar 14, 2012 @ 14:08
    Jeroen Breuer
    Did you select folders or images in DAMP? That xslt example simply shows all the images that are selected so if you only select images from 1 folder those are displayed.
    Jeroen
    Mar 14, 2012 @ 15:10
    Madde
    What do you mean by select?
    Im new to this plugin, im new to umbraco to
    Mar 14, 2012 @ 15:11
    Jeroen Breuer
    DAMP is a media picker. After you created media you need to select it. You can than display the selected images using your xslt example.
    Jeroen
    Mar 14, 2012 @ 16:04
    Madde
    I have two instances of damp in one page that picks from separate folders but my code example picks all of the images.
    So in div 1 it's images picked in instance one om DAMP and in div 2 it's pick images from instance 2 of DAMP
