  • Peter 89 posts 160 karma points
    Mar 22, 2012 @ 18:49
    Peter
    create link not showing
    I've come across an odd problem. In the content editing of a page where I have added the DAMP data type (which has options to make image type create-able) it is just showing choose.
    I've successfully used DAMP a couple of times in the past and loved it's awesomeness. it is awesome.
    It is the right control as when I press select it gives the DAMP overlay/selecter.
    Any ideas? have i configed something by mistake?
    Any suggestions would be appreciated.
    Peter
    Umbraco v4.7.1.1
    DAMP 2.0
    Mar 22, 2012 @ 18:56
    Peter
    Dumbass award goes to me.
    Tired eyes. reading the check box as if it was to show when it is to hide.
    hopefully another tired eyes dumbass will have the same problem and see this and take a break.
    P
    Mar 26, 2012 @ 10:15
    Jeroen Breuer
    Glad you found the problem. In the beta version of DAMP 2.0 it said "show" instead of "hide". This was changed later because we wanted to have it on by default.
    Jeroen
    Mar 26, 2012 @ 10:43
    Peter
    You're just trying to make me feel like less of a dumbass :)
    Thanks Jeroen!
