  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 9x admin c-trib
    Apr 30, 2012 @ 13:07
    Using DAMP together with CropUp cropper
    I am using the excellent Eksponent.CropUp package for cropping images and this equally excellent DAMP package for choosing the media.
    Unfortunately it seems that the "Edit" option doesn't work quite well with the CropUp cropper. It loads the image correct, but the croppings list (sidebar) doesn't load - so it's not possible to position the "focus" point correct, neither is it possible to define any custom crops on the image.
    Agreed, the awesomeness of the CropUp cropper lies in the fact that it's rarely necessary to actually change the defaults - still, it would be nice to be able to do this from within DAMP as we've been used (spoiled, yes) to.
    I guess I'd hoped that the "Edit" button simply opened the editor for the Media item somehow, but I guess that's not the case? Or is it really the CropUp cropper that does something unexpected?
    I'd like to hear if anyone is able to help with this - for now, I'll have to disable the "Edit" button in DAMP (which is itself excellent, that I can do that).
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    May 01, 2012 @ 09:30
    Jeroen Breuer
    Hi Chriztian,
    I haven't tested the Eksponent.CropUp with DAMP yet. The edit button opens the media item, but does some custom stuff. For example if you press the save button while editing the modal closes again. This required some modifications to the edit media page (so I made a custom version) and I guess that Eksponent.CropUp does something to the default edit media page which it doesn't to my version. Not sure if this needs to be fixed in DAMP or Eksponent.CropUp.
    Jeroen
    May 01, 2012 @ 11:10
    Thanks Jeroen,
    I'll try to investigate a little further - it'll probably need a little tweaking in both, I guess.
    /Chriztian
  • Niels Kühnel 16 posts 726 karma points
    May 01, 2012 @ 15:38
    Niels Kühnel
    I'm a little busy the next week, but I'll definitely look into DAMP integration when I get back to CropUp :)
  • Søren Reinke 158 posts 206 karma points c-trib
    Nov 06, 2012 @ 13:05
    Søren Reinke
    Any news regarding this topic?
    Do they work together?
    Nov 06, 2012 @ 13:09
    Jeroen Breuer
    You can find some more info here: https://gist.github.com/3826435
    Jeroen
    Nov 06, 2012 @ 13:27
    Søren Reinke
    Thanks ;)
    Jan 03, 2013 @ 14:38
    Jeroen Breuer
    I've released a custom version of DAMP which supports CropUp. You can watch a screencast here: http://www.screenr.com/caC7
    Jeroen
