  • Kim Bantz Rasmussen 81 posts 310 karma points
    Aug 17, 2012 @ 10:34
    Kim Bantz Rasmussen
    I have a problem with 4.8 ...
    Hi Forum!
    In the 'Cultiv Razor Examples' everything runs smooth as butter (4.7.1), but when a copy code into my new 4.8 project, it fails. I hope i can borrow a second pair of eyes :)
    This should list all 'timestamps' in a timeline, each with a image:
    @inherits umbraco.MacroEngines.DynamicNodeContext
    @using DigibizAdvancedMediaPicker;
        var root Model.AncestorOrSelf();
        var nodes root.Descendants().Where("NodeTypeAlias == @0 and Visible""Timestamp");
        <ul>
        @foreach (var node in nodes.OrderBy("timelineDate desc"))
             string[tagsList @node.tags.ToString().Split(',');
             //DAMP Classic
             dynamic media @node.MediaById(@node.timelinePhoto);
             <li style="color:#fff;">
                <h1>@node.pageTitle</h1>
                <h3 style="margin-top: 20px;">Razor DAMP classic sample</h3>
                <img src="@media.umbracoFile" alt="@media.nodeName" height="400px"/>
                @if (@node.HasProperty("tags"))
                  if (tagsList.Count(0)
                    <ul>
                    @foreach (var tag in tagsList)
                      <li><href="/timeline.aspx?tag=@tag" title="@tag">@tag</a></li>
                    </ul>
              </li>
        </ul>
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Aug 22, 2012 @ 09:49
    Jeroen Breuer
    Have you already been able to fix this? If not could you give some more info about the exception. For example the stack trace.
    Jeroen
    Aug 22, 2012 @ 10:31
    Kim Bantz Rasmussen
    Yes, it is fixed! Thanks!
    Code:
        <article class="eleven columns timelineElement element">
          <header>
            <span class="date">@node.timelineDate.ToString("dd.MM.yyyy")</span>
            <h1><href="@node.Url" title="@node.Name">@node.pageTitle</a></h1>
            <class="lead">@node.timelineTeaser</p>
            <href="@node.Url" title="@node.Name" class="readmore">&#9658; Læs mere</a>
          </header>
          <div class="elementImage">
          @if (@node.HasValue("timelinePhoto"){
            dynamic mediaItems @node.timelinePhoto.mediaItem;
              @if (mediaItems.Count(!= 0)
                foreach (var item in mediaItems)
                  var image item.Image;
                  <img data-original="@image.umbracoFile" src="/css/images/lazy.gif" class="lazy" alt="@image.nodeName" /
                  <noscript><img src="@image.umbracoFile" /></noscript>
            </a>
        </article
