Source Error:
Stack Trace:
umbraco.cms.businesslogic.property.Property.MakeNew(PropertyType pt, Content c, Guid versionId) +322
umbraco.cms.businesslogic.Content.createNewVersion() +611
umbraco.cms.businesslogic.Content.CreateContent(ContentType ct) +198
umbraco.cms.businesslogic.web.Document.MakeNew(String Name, DocumentType dct, User u, Int32 ParentId) +372
umbraco.cms.businesslogic.web.Document.Import(Int32 ParentId, User Creator, XmlElement Source) +369
umbraco.cms.businesslogic.packager.Installer.InstallBusinessLogic(Int32 packageId, String tempDir) +3599
umbraco.presentation.developer.packages.Installer.processInstall(String currentStep) +180
umbraco.presentation.developer.packages.Installer.Page_Load(Object sender, EventArgs e) +405
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +91
umbraco.BasePages.BasePage.OnLoad(EventArgs e) +14
System.Web.UI.Control.LoadRecursive() +74
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2207
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
I just tested DAMP 2.0 with the samples package on Umbraco 4.9 and it worked without any erros. Are you using SQL CE because that might give some errors.
Do it work in v4.9?
Do it work in v4.9?
I haven't tested it in 4.9 yet, but it should still work: http://our.umbraco.org/contribute/releases/490/rfc/33204-Media-Library-Enhancements#comment121963
Jeroen
I'm having issues installing the Samples in 4.9.
Source Error:
Jeroen
