  • Ivan 165 posts 543 karma points
    Sep 11, 2012 @ 11:57
    Ivan
    Accessing DAMP properties from within umbraco:item control.
    Hi guys.
    Ho do I access DAMP properites from within umbraco:item server control in Master Template?
    I can easily do the deed in XSLT template, like:
    <img src="{image/DAMP/mediaItem/Image/umbracoFile}" />
    But have no idea how it works in the server control. Any thoughts?
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Sep 11, 2012 @ 12:06
    Jeroen Breuer
    An umbraco item won't work because it will only output id's or xml and you'll need Razor or XSLT to transform that. It can be used in a UserControl, but you'll need some code to transform the id's or xml when you use node.GetProperty("alias").Value in there. DAMP has a helper which can be useful: http://damp.codeplex.com/SourceControl/changeset/view/62425cfc1854#DigibizAdvanceMediaPicker%2fDAMP_Helper.cs. For example the GetUrl method.
    Jeroen
  • Sob 11 posts 41 karma points
    Sep 13, 2012 @ 12:21
    Sob
    @jeroen Hi , I have a similar doubt, i want to show damp cropped image in my template.Is there any way to do it in template or i usually write razor for that.
    Thanks in advance.....
    Sep 13, 2012 @ 12:27
    Jeroen Breuer
    You usually write razor or xslt for that. It can be done in a masterpage if you use a code behind (see #Protip: Creating new templates at http://tech.kipusoep.nl/2010/07/23/umbraco-45-visual-studio-2010-dotless-jquery-vsdoc-squishit-masterpages/), but I think razor or xslt is easier.
    Jeroen
    Sep 13, 2012 @ 12:33
    Sob
    @Jeroen Breuer Reply was fast......Thanks .......:)
    Dec 17, 2012 @ 10:51
    Ivan
    Hi guys.
    Is there a chance to access DAMP image using XSLT expression on Umbraco:Item?
    <umbraco:Item field="favicon" runat="server" xslt="what should I type here to access umbracoFile node of DAMP?" />
    Dec 17, 2012 @ 10:58
    Jeroen Breuer
    I've never tried to fetch a DAMP image with inline XSLT so I don't know if that works. I think it's just better to do this in Razor or XSLT. You could try the new umbraco:Image control, but you'll probably need to write a DAMP provider for it.
    Jeroen
