  • Sören Deger 733 posts 2844 karma points c-trib
    Oct 09, 2012 @ 09:22
    Sören Deger
    DAMP auto crop not working in umbraco 4.9
    Hi Jeroen,
    I use the Digibiz Advanced Media Picker in Umbraco 4.9, but the auto crop function do not work! In Umbraco 4.7.1 it work's.
    If I upload one or more images in media section and call the crops in Razor, i.e.
    <img src="@crop.Find("@name), "Slider").url" />
    I got an razor error!
    If I crop the images manually, it work's.
    Best regards
    Sören
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Oct 09, 2012 @ 09:31
    Jeroen Breuer
    Hi Sören,
    I tested DAMP on 4.9 this weekend and I had no problems. I installed the samples package for testing (see this video: http://www.screenr.com/gz0s) and everything worked. Do you have the DAMP_CallImageCropper and DAMP_OnlyIfEmpty appSettings in the web.config set to true?
    Jeroen
    Oct 09, 2012 @ 09:42
    Sören Deger
    Hi Jeroen,
    thank you! I had the settings set to true. But now, it work's. The solution is very simple: I have uploaded two images in media section before I have installed the DAMP and selected this two images with any images by mistake. With new images it works perfectly! It's a great package!
    Sören
