I'm having some trouble with the DAMP PropertyEditorValueConverter. When using your strongly typed example:
var image = new DAMP.PropertyEditorValueConverter.Model(item.GetPropertyValue("logo"))
I'm getting the following error:
Compiler Error Message: CS1502: The best overloaded method match for 'DAMP.PropertyEditorValueConverter.Model.Model(string)' has some invalid arguments
This error is because the item.GetPropertyValue("logo") is already returning a DAMP.PropertyEditorValueConverter.Model instance.
Not what I was expecting, but ok, then I'll just use the following code:
var images = item.GetPropertyValue<DAMP.PropertyEditorValueConverter.Model>("logo");
This returns a Model, but if "logo" does not exist, it will return null instead of an empty DAMP_List. Because this option will require us to always check for null, this method is not prefered.
Not prefered:
if (images != null)
foreach (var image in images.Take(1))
<img src="@image.TypedCrops["frontpageslideshow"]" alt="@image.Alt" />
What I would like to do is the following:
var image = item
.FirstOrDefault();
if (image != null)
Or:
Or:
var images = new DAMP.PropertyEditorValueConverter.Model(item.GetPropertyValue("logo"))
Also, the Model() constructor does not check if a Media item actually exists before adding it to the list. If the logo property contains an media ID that does not exist (anymore), it will still add a empty DAMP_Item to the list. This means the Any and Count methods are meaningless, and it will cause errors in the DAMP_Item object when accessing properties on it. So could you check if a media item actually exists before adding a DAMP_Item to the list?
Thanks for the feedback. When I created this the focus was on dynamic and not strongly typed so there probably is room for improvement :-). Will soon release v1.3 and I'll try to fix some of these issues.
DAMP PropertyEditorValueConverter problems
Hey Jeroen,
var image = new DAMP.PropertyEditorValueConverter.Model(item.GetPropertyValue("logo"))I'm getting the following error:
Not prefered: var images = item.GetPropertyValue<DAMP.PropertyEditorValueConverter.Model>("logo"); if (images != null) { foreach (var image in images.Take(1)) { <img src="@image.TypedCrops["frontpageslideshow"]" alt="@image.Alt" /> } }What I would like to do is the following:
var image = item .GetPropertyValue<DAMP.PropertyEditorValueConverter.Model>("logo") .FirstOrDefault(); if (image != null) { <img src="@image.TypedCrops["frontpageslideshow"]" alt="@image.Alt" /> }Or:
var images = item.GetPropertyValue<DAMP.PropertyEditorValueConverter.Model>("logo"); foreach (var image in images.Take(1)) { <img src="@image.TypedCrops["frontpageslideshow"]" alt="@image.Alt" /> }
Or:
var images = new DAMP.PropertyEditorValueConverter.Model(item.GetPropertyValue("logo")) foreach (var image in images.Take(1)) { <img src="@image.TypedCrops["frontpageslideshow"]" alt="@image.Alt" /> }Also, the Model() constructor does not check if a Media item actually exists before adding it to the list. If the logo property contains an media ID that does not exist (anymore), it will still add a empty DAMP_Item to the list. This means the Any and Count methods are meaningless, and it will cause errors in the DAMP_Item object when accessing properties on it. So could you check if a media item actually exists before adding a DAMP_Item to the list?
Could you fix some of these issues?
Jeroen
Looking forward to it :-) Thanks for your quick response.
