  • Remko 118 posts 283 karma points
    Jan 28, 2013 @ 13:09
    Remko
    Not able to select a folder
    I've got the following problem: I created a new DAMP datatype, just to be able to select a folder within a DocumentType. I've configured it with the following settings:
    Within the document I get the following error:
    I'm using the latest Umbraco 4.11.3
    Can anyone please help me?
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Jan 28, 2013 @ 13:12
    Jeroen Breuer
    What happens when you try to click on one of the images on the left tree. What media type are those images? Perhaps they are a custom media type which you're not allowed to select?
    Jeroen
    Jan 28, 2013 @ 13:27
    Remko
    I've only got the default media types: File,Image and Folders...
    When I click on one of the other images, nothing really changes...
    Jan 28, 2013 @ 13:32
    Jeroen Breuer
    Haven't seen this before. What if you try to edit the datatype and don't check any of the allowed media types so everything should be allowed. Maybe than it works.
    Jeroen
    Jan 28, 2013 @ 13:36
    Remko
    I've already tried that. I'm just not able to select a folder, no matter what I try...
    Jan 28, 2013 @ 14:09
    Jeroen Breuer
    Sorry I don't know what the problem is. You could try to download the source code and debug it to find the problem: http://damp.codeplex.com/SourceControl/list/changesets?branch=default
    Jeroen
