  • Amir Khan 1289 posts 2746 karma points
    Feb 08, 2013 @ 18:00
    Amir Khan
    DAMP With Links?
    Is there a way to use the DAMP with links, allowing an end user to link the image to a content node?
    Feb 08, 2013 @ 19:45
    Amir Khan
    Alright, so I figured this out by creating a custom media type and adding a content picker property to it. Everything works great when using the content picker via the media section, but not via the DAMP dialog (the property doesn't get updated).
    Any ideas?
  • Brian Patton 33 posts 103 karma points
    Feb 20, 2013 @ 17:53
    Brian Patton
    odd...same problem here...did you find a solution?
    Feb 20, 2013 @ 19:18
    Amir Khan
    Nope, my workaround was to just add a content picker property to the document type...
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Mar 05, 2013 @ 17:05
