  • Matt 91 posts 237 karma points
    Apr 05, 2013 @ 11:50
    Matt
    Problem installing DAMP + Samples on server
    Using Umbraco v6.0.3 using WebForms on a development server:
    After installing DAMP, DAMP Razor Model, and DAMP Razor Model Samples I get this error when viewing the sample page:
    Error Loading Razor Script (file: DAMP- Razor) 'umbraco.MacroEngines.DynamicXml' does not contain a definition for 'longImage'    at CallSite.Target(Closure , CallSite , Object )
    When I create a localhost, clean version of v6.0.3 and install the same packages there is no problem. Is there anything obvious I could be missing?
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Apr 05, 2013 @ 15:14
    Jeroen Breuer
    Sorry the DAMP Razor Model Samples package doesn't work on v6. If you want some good examples it's best to try the DAMP Gallery and upgrade that to v6.
    Jeroen
    Jeroen Breuer
    Jeroen
