  • Craig100 1136 posts 2523 karma points c-trib
    Apr 07, 2013 @ 21:27
    Craig100
    DAMP GetImageCropperUrl Help
    In this bit of code,
            @foreach (dynamic theImagePage in Model.Descendants("sliderBanner").Where("umbracoNaviHide == false")) { //for each banner page in the repository
                ///// NEXT LINE IS WRONG /////
                dynamic imageItem = theImagePage.bannerImmage.mediaItem.HomePageBanner.First();
                var theCrop = DAMP_Helper.GetImageCropperUrl(imageItem, "sliderImage");
    //do some stuff
    Can anyone clear up what the 1st argument in GetImageCropperUrl(DynamicXml mediaItem, string cropName) should be from this XML as I'm totally confused:-
          <sliderBanner id="1116" parentID="1115" level="3" creatorID="0" sortOrder="0" createDate="2013-04-06T22:28:56" updateDate="2013-04-07T18:43:44" nodeName="Banner 1" urlName="banner-1" path="-1,1065,1115,1116" isDoc="" nodeType="1112" creatorName="admin" writerName="admin" writerID="0" template="0">
            <umbracoNaviHide>0</umbracoNaviHide>
            <bannerImage>
              <DAMP fullMedia="">
                <mediaItem>
                  <HomePageBanner id="1119" version="e68932f4-d24c-484b-9ced-d662dac6e429" parentID="1118" level="2" writerID="0" nodeType="1104" template="0" sortOrder="0" createDate="2013-04-06T22:41:19" updateDate="2013-04-07T11:39:10" nodeName="banner-fruit" urlName="banner-fruit" writerName="admin" nodeTypeAlias="HomePageBanner" path="-1,1118,1119">
                    <sliderImage>
                      <crops date="2013-04-06T22:41:19">
                        <crop name="sliderImage" x="0" y="0" x2="960" y2="377" url="/media/1016/banner-fruit_sliderImage.jpg" />
                      </crops>
                    </sliderImage>
                    <umbracoFile>/media/1016/banner-fruit.jpg</umbracoFile>
                    <umbracoWidth>960</umbracoWidth>
                    <umbracoHeight>378</umbracoHeight>
                    <umbracoBytes>172343</umbracoBytes>
                    <umbracoExtension>jpg</umbracoExtension>
                  </HomePageBanner>
                </mediaItem>
              </DAMP>
            </bannerImage>
            <caption><![CDATA[5 a day keeps the doctor away!]]></caption>
            <linkAddress>http://www.nhsdirect.nhs.uk</linkAddress>;
          </sliderBanner>
    I just want the url for the crop but can't make it work.
    Have had so much trouble with Custom DAMP saving only ID, thought saving as XML might be clearer, but hey ho!
    Craig
    Apr 07, 2013 @ 21:33
    Craig100
    Couldn't safely edit above...
    Am using the DAMP Razor model, (non-MVC version) with just the following in the head of the file:-
    @inherits umbraco.MacroEngines.DynamicNodeContext
    @using DigibizAdvancedMediaPicker;
    Apr 16, 2013 @ 12:36
    Jeroen Breuer
    If you're using the DAMP Razor model you shouldn't use GetImageCropperUrl (which is an old helper). You should do this:
    dynamic imageItem = theImagePage.bannerImage.First;
    var theCropUrl = imageItem.Crops.sliderimage;
    <img src="@theCropUrl
    " alt="@imageItem.Alt"/>
    Jeroen
