  • Kim Bantz Rasmussen 81 posts 310 karma points
    Apr 15, 2013 @ 09:14
    Kim Bantz Rasmussen
    DAMP and value of custom property
    Hey,
    This is properly very easy to do but I can't get custom properties from my image.
    My custom field in the image datatype is called Description. How can I show the value of that field?
    My code so far:
    @inherits umbraco.MacroEngines.DynamicNodeContext
    @using DigibizAdvancedMediaPicker;
            if (Model.HasValue("backgroundImages")) {
                dynamic mediaItems = Model.backgroundImages.mediaItem;
                if (mediaItems.Count() > 1) {
                  foreach (var item in mediaItems) {
                    var image = item.Image;
                    <li><br />
                      @image.imageCropper.Find("@name", "background").url
                                     <br />
                      @image.Image.umbracoFile
                          <br />
                      <p>@image.Image.nodeName    </p>
                    </li>
            else {
                    @Html.Raw("")
    Umbraco 6.0.3
    Best regards
    Kim
    Apr 16, 2013 @ 12:47
    Jeroen Breuer
    Did you try the following?
    var description = image.Description //which is the property alias.
    Jeroen
    Apr 16, 2013 @ 13:24
    Kim Bantz Rasmussen
    Hi Jeroen,
    Yes, but it didn't work :(
    Am I doing it wrong?:
                    var description = image.Description;
                    <li>
                      <p>@image.Image.nodeName</p>
                      <h1>@description</h1>
                    </li>
            else {
                    @Html.Raw("")
    Apr 16, 2013 @ 13:33
    Jeroen Breuer
    Usually the alias doesn't have a capital so try item.description.
    Jeroen
    Apr 16, 2013 @ 13:52
    Kim Bantz Rasmussen
    Thank you very much - that did the trick!
    Best regards
    Kim
  • Craig100 1136 posts 2523 karma points c-trib
    Apr 23, 2013 @ 11:56
    Craig100
    I have a similar situation. I added a "Caption" property to the Image mediaType. However, I can't get the caption out.  If I have theCaption = "Hello" it all works.
    @using Eksponent.CropUp;
       if (Model.galleryImages.Any) {
       <div class="gallery">
               @foreach(dynamic image in Model.galleryImages){
                   var theThumbCrop = CropUp.GetUrl(image.File, new ImageSizeArguments { Width = 100, Height = 100, CropAlias = "thumbnail" });
                   var theFullCrop = CropUp.GetUrl(image.File, new ImageSizeArguments { Width = 800, Height = 600, CropAlias = "galleryMax" });
                   var theCaption = image.caption;
       <a href="@theFullCrop" rel="gallery1" class="fancybox" title="@theCaption"><img src="@theThumbCrop" width="100" height="100" alt="@theCaption"></a>
    DAMP 2.5 Umb V6.0.3
    Craig
