I have a website that needs to go live asap. Have DAMP picker for Photo Gallery and many such media pages.
I've installed DAMP package, created a Data Type to link with this picker, added this type in Doc Type and created content nodes with this property populated.
In the local and test version of the same website, it worked fine. I could "Choose..." a media node, and as soon as a folder is chosen, it'll load all images (thumbs of them) on the selection panel. From there I could pick the necessary images. (just listing all of these to make sure none of the step makes it go wrong)
On live website though, I can not see image thumbs "loading..." in the selection pane in the middle of DAMP picker. I tried uninstall and reinstall of the package, save and republish etc. Nothing seems to solve it.
Issue Selecting a Media node in DAMP picker
DAMP 2.5 on Umbraco 6.0.5
greatly appreciate if this can be solved. Thanks
If DAMP works on your local and test version perhaps there is a problem with the rights on your live server? I haven't seen this issue before.
Jeroen
