  • Barry Fogarty 493 posts 1129 karma points
    Oct 14, 2013 @ 09:34
    Barry Fogarty
    DAMP recursive properties with Value Converter
    When I run the following line:
    var dampModel = node.GetPropertyValue<DAMP.PropertyEditorValueConverter.Model>(propertyAlias, recursive, null);
    it works fine when recursive = false, it returns a DAMP model object, but when on a child document with recursive = true, it returns null.
    Is it because of this Umbraco issue?   Is there a workaround that still returns a DAMP.PropertyEditorValueConverter.Model?
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Oct 14, 2013 @ 09:40
    Jeroen Breuer
    101
    Yes it's related to that Umbraco issue. Currently the only workaround is to first find the node you are looking for and do .GetPropertyValue<DAMP.PropertyEditorValueConverter.Model>(propertyAlias) on that.
    Jeroen
    Oct 14, 2013 @ 10:23
    Barry Fogarty
    Thanks for the quick reply Jeroen.
    Is there a DAMP helper like Umbraco.TypedMedia?  In my case it made more sense to do
                var imageId = node.GetPropertyValue<string>(propertyAlias, recursive, null)
    and cast it to a media item as follows
                var image = new UmbracoHelper(UmbracoContext.Current).TypedMedia(imageId);
    In this situation I did not need crops but would be nice to cast to be able to cast to a DAMP object from a media ID.
    Oct 14, 2013 @ 11:48
    Barry Fogarty
    Just to follow up, there was one snag with my code above . I needed to cast the imageId to an int first, to prevent the DAMP property editor value converter from running:
    var imageId = node.GetPropertyValue(propertyAlias, recursive, 0);
    Only then would the TypedMedia call work.
  • Ali Sheikh Taheri 470 posts 1648 karma points c-trib
    Apr 10, 2014 @ 17:54
    Ali Sheikh Taheri
    Hi Jeroen,
    do you know how can I convert Dynamic XML to Damp Model? (using umbraco 6.1.5)
    the problem is when I do this page.GetPropertyValue("image",true,null) it returns an object which is dynamic xml and now I need to convert it do damp model?
    Cheers
    Ali
    Apr 10, 2014 @ 17:59
    Jeroen Breuer
    I need some more code to see how it currently works before I can help you. Can you paste the page where you are using that part?
    Jeroen
    Apr 10, 2014 @ 18:20
    Ali Sheikh Taheri
    the problem is this http://issues.umbraco.org/issue/U4-1958.
    so I cannot use GetPropertyValue<DampModel>("image", true, null)
    and in your comment above you mentioned that
    "Currently the only workaround is to first find the node you are looking for and do .GetPropertyValue
    my question is how to get that node?
    the only way I know is to do CurrentPage.GetPropertyValue("image",true) but this returns dynamic XML of the image :
    <DAMP><mediaItem><Image id="3694" version="b4c57f37-b833-44e0-b2f2-14f83bec3005" parentID="1078" level="2" writerID="0" nodeType="1032" template="0" sortOrder="30" createDate="2014-03-24T14:18:28" updateDate="2014-03-26T11:50:58" nodeName="header-right-hand" urlName="header-right-hand" writerName="abv" nodeTypeAlias="Image" path="-1,1078,3694">
                    <umbracoFile>/media/1202/header-right-hand.jpg</umbracoFile>
                    <umbracoWidth>1120</umbracoWidth>
                    <umbracoHeight>480</umbracoHeight>
                    <umbracoBytes>197676</umbracoBytes>
                    <umbracoExtension>jpg</umbracoExtension>
                    <altText />
                  </Image>
                </mediaItem></DAMP>
    so the quesiton is how to convert this into DampItem or DAMP.PropertyEditorValueConverter.Model
    I hope this makes sense. I dont have much code to paste here than above.
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    Apr 10, 2014 @ 18:56
    Jeavon Leopold
    Two solutions for you:
    1. Upgrade to Umbraco 6.2RC or 7
    2. Do something like the below:
    Snippet
        var mapImage = Model.Content.AncestorsOrSelf().Where(x => x.HasProperty("mapImage") && x.HasValue("mapImage")).FirstOrDefault();
        if (mapImage != null){
            <div class="maplink-map" style="background-image: url(@(mapImage.GetPropertyValue<DampModel>("mapImage").First.Url))"> </div>
    Apr 10, 2014 @ 19:02
    Ali Sheikh Taheri
    thank you so much Jeavon, the snippet is exactly what I needed
    Cheers
    Ali
