  • Asbjørn 82 posts 195 karma points c-trib
    Dec 07, 2013 @ 12:09
    Asbjørn
    Issue with IE11
    When I add DAMP to a datatype in Umbraco 6.1.6 and then display the editor in IE11, the page does not expand to fill the window (as happens when DAMP is not present). Also, I get two JS errors (translated from Danish):
    String constant not terminated
    'LoadDamp' is not defined
    The first error leads to this piece of code:
    + "</script></head><body>[>error here]
    <!-- Visual Studio Browser Link -->
    <script type="application/json" id="__browserLink_initializationData">
        {"appName":"InternetExplorer"}
    </script>
    <script type="text/javascript" src="http://localhost:52317/b7c1c514b4544cc3826f028c1182c1c9/browserLink" async="async"></script>
    <!-- End Browser Link -->
    </body></html>";
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Dec 07, 2013 @ 12:31
    Jeroen Breuer
    I've released DAMP 2.7 yesterday in which this issue should be fixed.
    Jeroen
    Feb 18, 2014 @ 21:16
    Asbjørn
    I never got around to saying thank you for the fix - of course version 2.7 did indeed fix the issue :)
    Feb 19, 2014 @ 09:31
    Jeroen Breuer
    Glad that fixed the issue. Could you please mark a post as the solution if it helped you.
    Jeroen
