    Jan 10, 2014 @ 16:49
    Anthony Candaele
    issue with DAMP Property Editor Value Converter
    Is there an issue with DAMP Property Editor Value Converter (version 1.2) and Umbraco 6.1.6 ?
    When I try to run this code, I get a KeyNotFoundException:
    @foreach (var sponsor in sponsors)
            if (sponsor.HasValue("sponsorImage"))
                      var image =  sponsor.GetPropertyValue<DAMP.PropertyEditorValueConverter.Model>("sponsorImage");
                      <li class="block">
                          <img alt="@image.First.Alt" src="@image.First.TypedCrops["sponsorcrop"]" />
                      </li>
    This code worked fine in previous Umbraco installs.
    greetings,
    Anthony
    Jan 13, 2014 @ 10:56
    Anthony Candaele
    Anyone an idea why this code isn't working?
    I access the sponsor nodes like this:
    var sponsors = Model.Content.DescendantsOrSelf().Where(x => x.DocumentTypeAlias == "Sponsor");
    It's returning 4 IPublishedContent objects, holding the sponsor data.
    When debugging, I get a KeynotFoundException on this line:
    thanks for your help,
    Anthony
    Jan 13, 2014 @ 11:23
    Anthony Candaele
    Found the issue, it was caused because there wasn't defined a crop (sponsorCrop) in the Sponsor Image Cropper property (of type Image Cropper). I guess this happened because I didn't define a width when creating the Sponsor Image Cropper propery.
    Which brings me to my next question, how can I define an Image Cropper property for images with variable heights.
    Thanks for your help,
    Anthony
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Jeroen Breuer
    Can you give the stacktrace of the KeynotFoundException exception? Something probably goes wrong with creating the DAMP model, but I don't really know what it is.
    Jeroen
    Jan 13, 2014 @ 11:29
    Anthony Candaele
    Hi Jeroen, our posts crossed. The issue is solved, there wheren't any crops created because the crop definition in the Image Cropper was empty.
    The only problem I need to solve now are the dimensions of the sponsor logo's:
    Is their a way to retain aspect ratio for images of variable heights ?
