If you're using DAMP 2.0 you can just install the DAMP 2.7 package and everything should work. You could also first uninstall the DAMP 2.0 package and than install it.
It´s recommended to check the prevalues in the Data Types to see if everything is still correct after upgrading."
Cant create images with DAMP
Hello sirs,
I've added a DAMP media picker to a doctype. No surprise there :-)
When I use create to upload a new image it always fails.
Steps:
What version of DAMP are you using and what version of Umbraco? Only DAMP 2.5 and higher work on Umbraco 6.
Jeroen
Hmm .. cant see which version it is since the package xml file has been overridden during an upgrade. Any other way to check the version?
You can look in \Umbraco\Plugins\DigibizAdvancedMediaPicker\Installer.ascx
It has a message with "Digibiz Advanced Media Picker 2.7 successfully installed!".
You could also just install DAMP 2.7 and check if you still have the problem afterwards.
Jeroen
Im gonna do exactly that. Upgrade that is. Is it as easy as just installing the package?
Copied from package page ;-)
"Upgrading
Just install should work :-).
Jeroen
Of couse .. sorry my bad. I was to quick while scanning the text and went directly to the documentation tab where there was a sample. Thx again!
