  • Daniel Palm 36 posts 148 karma points
    Apr 22, 2014 @ 00:26
    Daniel Palm
    SQL Error when saving full XML
    I´m using Umbraco 6.1.6 with Damp 2.8. At first I set Damp to save Id only and that worked fine. When I tried to set Damp to save full XML I got at SQL Error (when saving a page with damp-images):
    String or binary data would be truncated.
    The statement has been terminated.
    Exception Details: System.Data.SqlClient.SqlException: String or binary data would be truncated.
    Source Error:
    Stack Trace:
    [SqlException (0x80131904): String or binary data would be truncated.
    The statement has been terminated.]
       System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +1767866
       System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +5352418
       System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +244
       System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +1691
       System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() +61
       System.Data.SqlClient.SqlDataReader.get_MetaData() +90
       System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +365
       System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds) +1406
       System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite) +177
       System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +53
       System.Data.SqlClient.SqlCommand.ExecuteScalar() +149
       StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteScalar() +60
       Umbraco.Core.Persistence.<>c__DisplayClassa.b__9() +56
       Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction(Func`1 func) +170
       Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteScalarWithRetry(IDbCommand command, RetryPolicy cmdRetryPolicy, RetryPolicy conRetryPolicy) +118
       Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteScalarWithRetry(IDbCommand command, RetryPolicy retryPolicy) +52
       Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteScalarWithRetry(IDbCommand command) +49
       Umbraco.Core.Persistence.Database.Insert(String tableName, String primaryKeyName, Boolean autoIncrement, Object poco) +1667
       Umbraco.Core.Persistence.Database.Insert(Object poco) +51
       Umbraco.Core.Persistence.Repositories.ContentRepository.PersistUpdatedItem(IContent entity) +2458
       Umbraco.Core.Persistence.Repositories.RepositoryBase`2.PersistUpdatedItem(IEntity entity) +48
       Umbraco.Core.Persistence.UnitOfWork.PetaPocoUnitOfWork.Commit() +256
       Umbraco.Core.Services.ContentService.SaveAndPublishDo(IContent content, Int32 userId, Boolean raiseEvents) +560
       umbraco.cms.businesslogic.web.Document.SaveAndPublishWithResult(User u) +351
       umbraco.cms.presentation.editContent.Publish(Object sender, EventArgs e) +75
       umbraco.controls.ContentControl.DoSaveAndPublish(Object sender, ImageClickEventArgs e) +75
       System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e) +115
       System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument) +124
       System.Web.UI.WebControls.ImageButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
       System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
       System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +35
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1724
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18408
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Apr 22, 2014 @ 09:17
    Jeroen Breuer
    DAMP stores the value different as xml. I never tried to switch it from ids to full media xml in v6. Might be better to create a new datatype and new property that stores the data as full media xml from the beginning. Than it should work just fine.
    Jeroen
    Apr 22, 2014 @ 22:29
    Daniel Palm
    Yes, that worked.
    Thanks!
