I installed the new package 2.8 on Umbraco v6.2.0 (Assembly version: 1.0.5234.23398) and its not working, DAMP data type does not appear in the selection of the Property editor at the DataTypes, Developer section.
Is there any way to fix it? Or i need to wait for the next version?
Umbraco 6.2.0 and DAMP 2.8
Please it's very important for me..
Thanks in advance.
I'm using DAMP on 6.2.0 and it's just working. When you create a new datatype does it appear in the property editor dropdown?
Jeroen
No, What should be the name?
As I remember it's something with "Dibiz" or "DAMP", I don't see anything like that..
Hmm strange. It should appear there. The name is Digibiz Advanced Media Picker. I have no idea why you can't see it.
Jeroen
I'm working on my local machine, maybe it affects somehow?
It might be related to this issue: http://issues.umbraco.org/issue/U4-4789
Looks like it will be fixed in 6.2.1.
Jeroen
Could you try the solution in this tweet? https://twitter.com/crumpled_jeavon/status/465754964263174144
Jeroen
Solution in the tweet worked for me. Thanks Jeroen.
The tweet worked for me too. Thanks Jeroen!
