I have installed this dictionary package and also manually refreshed the ClientDependency. This can be done by deleting the \App_Data\TEMP\ClientDependency folder and updated the version number in the ClientDependency.config file. But i didn't get anything in dictionary item . Is there step remaining from my side?
Well that should be it. If you create a dictionary item in the settings section it should also appear in the new dictionary section and vice versa. Sorry no idea what might be wrong.
have tried with restarting as well as reinstalling the same but still not getting anything...I have umbraco version is 4.5 ..does it support this package?
'Digibiz Dictionary Section'
Jeroen
now what to do? is there any solution for the same?
You could try to restart the app pool. I heard that sometimes also helps.
Jeroen
Yes 4.5 should support this package, but it only works on .NET 4.0. If you have .NET 3.5 read this topic: http://our.umbraco.org/projects/backoffice-extensions/digibiz-dictionary-section/digibiz-dictionary-section/20127-aspnet-35
Jeroen
yes, i have .Net 4.0 eventhough it's not working.
I'm sorry but I don't think I can help you. No idea why it doens't work. As an alternative you could try to add the dictionary section youself. See this post: http://our.umbraco.org/projects/backoffice-extensions/digibiz-dictionary-section/digibiz-dictionary-section/20127-aspnet-35?p=0#comment77200
Jeroen
Are you logged in as the admin? By default only the admin (with id 0) get's rights to this section.
Jeroen
yes..i have logged in as admin. i will try to run this code : http://our.umbraco.org/projects/backoffice-extensions/digibiz-dictionary-section/digibiz-dictionary-section/20127-aspnet-35?p=0#comment77200 and check once.
Can u tell me how do i write this code and run the same ?
