Just gave this package a spin and it works nicely :)
A thought just popped into my head. It would be nice if it was possible to somethow hide some of the entries.
For instance we have some system specific translation a normal editor should not be able to see or edit.
Therefore I'm thinking it would be ace if this package could be expanded with a config file where it would be possible to enter an id of the item to be hidden. And if it has children they are hidden as well.
Thanks for the suggestion. Currently it's pretty basic and only shows the dictionary tree from settings section so adding this might be a lot of work. I actually don't use this package anymore and I've switched to the Dictionary Dashboard package.
I realise that it would probably take a lot of extra work - just a thought :)
Yes I've seen that package as well, but decided that yours was a better fit for the current project we're working on - even though the dictionary dashboard is also really nice.
Suggestion: Possible to hide entries
Hi Jeroen
Hope this suggestion makes sense.
Jan
Hi Jan,
Jeroen
Hi Jeroen
