    Jul 07, 2010 @ 17:39
    dandrayne
    Update for 4.5 compatibility?
    Hi Tim
    Are there any plans for supporting version 4.5?  As luck would have it, a (strong) need has arisen for this package and it's a 4.5 project.
    Or if you have no plans to update it soon, do you have any advice on where to start?  I'm happy to upgrade the xslt files but they alone don't seem to be producing results.
    Dan
    Jul 07, 2010 @ 17:52
    dandrayne
    To be more specific, the following xml seems to get appended to my main xml for the site, although there are no results nodes listed.
    ><location name=" Edinburgh, Midlothian EH11, GB" latitude="55.9318218" longitude="-3.2595728" unit="miles" lowestDistance="-1" highestDistance="-1">55.9318218,-3.2595728</location>
    I'm assuming this is the location of the searcher, but there are no results nodes.
    To store the locations of the branches I've tried the locator datatype, Darren's google maps datatype and a straight textfield.
    Dan
  • Yannick Smits 321 posts 718 karma points
    Jul 08, 2010 @ 00:18
    Jul 08, 2010 @ 11:23
    dandrayne
    The xslt I can convert manually, but I suspect there's more at play here!
  • Tim Geyssens 6524 posts 15306 karma points MVP 2x c-trib
    Jul 09, 2010 @ 15:45
    Tim Geyssens
    Hi Dan,
    Just updated the package today, the new version 1.1 should work on both umbrac 4.0.X and 4.5
    Tim
    Jul 09, 2010 @ 15:53
    dandrayne
    Alas, I have but one upvote!
    Cheers Tim, great package
  • Lee 1123 posts 3059 karma points
    Sep 13, 2010 @ 21:13
    Lee
    Do I need to switch on legacy to get this to work with 4.5?
    Sep 14, 2010 @ 08:04
    Tim Geyssens
    Nope it should work if you are running the 1.1 version. Could you check the xslt, is that using the new schema? It might be that the package failed to update the xslt to the new schema, the new schema xslt should be in the package so you can just overwrite it ...
    Sep 14, 2010 @ 08:37
    Lee
    No worries I'll take a look in the package, its definitely got the old schema in the site now.
