  • Kin 30 posts 172 karma points
    Apr 20, 2016 @ 15:13
    Kin
    404 trying to load "TraceLogViewer/TraceLog/GetLogData" with virtual path
    my Umbraco installation is at "mywebsite.com/MyVirtualPath/" and it causes me to have a 404 when trying to load /Umbraco/Backoffice/TraceLogViewer/TraceLog/GetLogData
    A potential fix would be to edit EditController.js, line 21 from
    var dataUrl = '/Umbraco/Backoffice/TraceLogViewer/TraceLog/GetLogData?logfileName=' + $routeParams.id;
    to
    var dataUrl = 'Backoffice/TraceLogViewer/TraceLog/GetLogData?logfileName=' + $routeParams.id;
    What do you think?
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Apr 20, 2016 @ 18:43
    Dan Diplo
    Thanks, I'd never tried it using a virtual path - I wasn't even sure if Umbraco supported virtual directories.
    So does using a relative URL with a prefixing slash sort the issue? Does everything else work OK? If so, I'll put this in the next release.
    Apr 20, 2016 @ 18:57
    Kin
    The change I proposed fixed things on my side.
    I don't know if this is called somewhere other than from the Developper tab tho.
    Apr 20, 2016 @ 19:26
    Dan Diplo
    Thanks, I've tried locally and it all seems to work, so this will definitely go in the next release!
    Apr 20, 2016 @ 19:52
    Kin
    Thank you. :)
    May 04, 2016 @ 07:32
    Dan Diplo
    Just to let you know the latest release includes the virtual path fix - thanks for your help :)
    https://www.nuget.org/packages/DiploTraceLogViewer/
    https://our.umbraco.org/projects/developer-tools/diplo-trace-log-viewer/
