This donut caching seems pretty cool so I've been looking into it a bit.
I did wonder how much use it would be with Umbraco where the content XML is already cached but it does make a difference. I suppose you just have to consider if you can afford the extra memory.
Rather than decortaing all your controller actions with the same caching options you can simply add the following within the system.web section of the web.config:
The declaration on the controller action then becomes:
[DonutOutputCache(CacheProfile="OneDay")]
The advantage is you don't have to search all your code to make a change and a any modifications are quickly made in the web.config so no recompilation and assebly deployment.
Thanks for the idea. For the next version I might use your suggestion.
Umbraco with MVC can be very fast, but I also notice that using DonutOutputCache still makes a difference. Websites that load in 300ms server side are only 60ms after using the DonutOutputCache attribute.
Another big benefit is that if you set the duration in the web.config to 0 you can disable donut cache during development and you don't need to comment the attribute everywhere.
Donut caching - Profiles
I wanted to share something I found, Using a cache profile.
Matt
Jeroen
Jeroen
That's right. :-)
