  • Chris 10 posts 40 karma points
    Jul 03, 2012 @ 21:32
    Chris
    Blank results
    Hi - just installed the Locator Razor Style package.
    I have it set up as indicated... Documents of alias "dealer", with a property of "location" using the Google Maps Datatype.
    I've created two dummy "dealer" documents for testing purposes.  And I've inserted the locator macro on my page and fed it the correct query string.
    However, I get no results - as if the macro isn't there.  However, if I do not submit the query string, I do get a "Please enter a search term", which indicates that the macro is running, correct?
    Any help would be appreciated.
    One note:  do my "dealer" documents have to be assigned a template in order for the locator to work?  This was one thought I had, but adding a template did not solve the problem.
    Jul 03, 2012 @ 22:42
    Chris
    Did not realize it, but I was actually having the same problem as:
    http://our.umbraco.org/projects/developer-tools/locator-razor-style/help-using-the-locator/23660-Please-provide-a-search-term
    The solution posted there to use "Value" instead of "ToString()" worked for me.
