  • Jamie Robb 10 posts 40 karma points
    Aug 29, 2013 @ 13:36
    Jamie Robb
    Locator Razor package suddenly stopped working?
    Hi folks,
    We appear to be having an issue with all our live websites which use this package with google maps - basically any page which uses it is failing to load and just times out.
    Has anyone else encountered problems?
    Jamie
    Aug 29, 2013 @ 13:48
    Jamie Robb
    Forgot to add that the package still works fine in our local development environment, it's just on the live websites it seems to have suddenly stopped working :/
  • Tim Geyssens 6467 posts 15146 karma points MVP 2x c-trib
    Aug 29, 2013 @ 13:50
    Tim Geyssens
    Maybe you've hit the google usage limit https://developers.google.com/maps/documentation/javascript/usage?hl=nl
    Any js errors ?
    Aug 29, 2013 @ 13:51
    Tim Geyssens
    Or a new doc that doesn't have the coordinates stored causing issues...
    Aug 29, 2013 @ 14:24
    Jamie Robb
    Hi Tim, thanks for replying so quickly.
    I think we appear to be over the query limit, so every time we call the line - GeoResponse r = GoogleGeoCoder.CallGeoWS(Request["s"]); - it's empty because the API is returning a status of "OVER_QUERY_LIMIT".
    Don't suppose you've any ideas how we can get around this??  If we got an API key per site then would that help to split up the usage between all sites using the package?
    Jamie
    Aug 29, 2013 @ 14:56
    Tim Geyssens
    Doesn't work with api keys anymore so guess you'll need to purchase additional quota from google https://developers.google.com/maps/documentation/javascript/usage
    Aug 29, 2013 @ 17:45
    Jamie Robb
    Cheers for your help.
    I thought at first there was no way we'd hit the limit since it's 25,000 a day, then I discovered that the limit for the Geocoding API is a lot less (2,500 apparently).
    Had a dig about one of our recently launched websites and think we've found some unnecessary (and frequent) calls to the API which may have caused us to reach the quota. Hopefully our quota resets back to 0 tomorrow!
    Jamie
