I was wondering if there was a way to populate the Static SEO TItle field from a field on the homepage of a site? Would be great for visualizing the SERP title for multi site installations.
Sorry for the delay in coming back to you. Thank you for the kind comment.
Not quite sure what you mean - could you clarify and I will try to amend for your needs?
In your options you have a setting called "Static SEO Title" which is great for an Umbraco installation containing a single site. For our multi site installations, we often set the text that is appended to the page specific portion of the title tag in a settings field on the homepage of each site along with a specific body class, logo, etc. It would be great to be able to do this with your package so editors could see the full page title title specific to each site.
Grab Static Title from Settings Field
Hi, this project is fantastic!
Thanks!
Amir
Hi Amir,
Sorry for the delay in coming back to you. Thank you for the kind comment. Not quite sure what you mean - could you clarify and I will try to amend for your needs?
Regards, L
Hey Luke!
Does that make sense?
Thanks!
Amir
Yuo can create a new datatype uSeoPro from developer section -> datatype
Thanks Biagio,
Yes, I would agree - create a new distinct uSeoPro datatype for each of your multi site root node.
Regards, Luke
That's going to be challenging if the same document type is ever shared across sites. Shared content for example.
-Amir
