It seems like a check for the SEO title field never returns null or empty unless you actually enter something into it and delete it.
I'm using essentially the sample view you've shared to check for it. Thoughts?
Thanks!Amir
Hi Amir,
I think this is my error. The function part should read:
@functions { private bool IsNullOrEmpty(object property) { return property == null || String.IsNullOrEmpty(property.ToString()); } }
I am going to update the project page - thank you and my apologies.
Regards, Luke
Upload image
Title Field Isn't Empty by Default
Thanks!
Amir
Hi Amir,
Regards, Luke
